Why i can't put DVBViewer window in corners?
PlayMaker
I can't put DVBViewer window in screen corners, there is always some space in there. Is this bug? You can see it in ss.
Confirmed for Windows 10. In older versions of Windows the DVBViewer window snaps to the very edge of the screen when it's moved to within a few pixels of that edge. In Windows 10 however it snaps to an imaginary border a few pixels away from the edge, as in your screenshot.
The problem occurs only on the bottom, left and right edge of the screen – not the top edge. Also, using the Windows-Key + Cursor left/right combination does move the window to the very edge of the screen.
This appears to be another minor compatibility issue with Windows 10 that DVBViewer has (another is the white bar at the top of the window, when View → Hide All is selected).
This problem will solved in next version? If yes, when will next version released? Btw there was no problem in old DVBViewer versions in Windows 10.
