bjanuszs46 Posted January 22, 2016 Posted January 22, 2016 I removed the files from the disk (actually archived them on another one) but the titles are still offered by UpnP. Following http://en.DVBViewer.tv/wiki/Options_Recorder I've tried "Delete Orphans" but the buttom simply doesn't seem to work. "Refresh Database" takes some time but nothing changes. I will appreciate your advice. Best regards Janusz Quote
Tjod Posted January 22, 2016 Posted January 22, 2016 If the file was in recordings removing the recording file (and EPG info .txt) and ruing "Cleanup Recording DB" (web interface > Tasks > Recordings) should remove the recording from the database. The "Delete Orphans" in the DVBViewer settings is only for the DVBViewer database not for the one from the RS. Quote
bjanuszs46 Posted January 22, 2016 Author Posted January 22, 2016 Yes, it was RS. Thank you very much! Janusz Quote
