Terratec Cinergy C PCI HD -REMOTE
rodjd
Please HELP me too resolve this big problem,i have this terratec tv card,but remote 2400iDT not work with DVB,volume is not corect,programme +/- is not corect,i tried in input but i see only key from keyboard,how i configure this remote?
Nobody helps me ?
Remote is work,only big problem is how i configure ???
volume -not work
chanell change -not work
Edited by rodjd
OK,not response,via P.M no,via forum no,what is this ???
Please help me with .remote for this tv card.
http://en.DVBViewer.tv/wiki/Options_Input
Press Learn click on the command and then press the key on you remote control.
Make sure that all keys on the remount are sending different signals. In some remote up and next channel are the same command.
In this case only configure the up/down right/left keys.
Thanks Tjod,I tried,i press Learn,i click on the volume + in menu,i press volume + on remote,but nothing.
Nobody have a .remote too inport in my DVBViewer ?
Please :(
this is remote :
original-terratec-remote-control-univers
Edited by rodjd
No one has this remote control ?
P.M. too .remote file PLEASE :(
I usedto use this remote on a previous computer and it worked fine. If you follow the instructions in the wiki, and make sure that you press "Learn Off" and "Save" when you are finished programming and that the correct remote file is loaded when you start the software.
It only takes a few minues and is worth the little bit of effort.
In DVBViewer i make this:
1.options
2.input
3.learn on
4.click key
5.click remote key (i have terratec soft)
6.save
? corect ?
