I need channel list pls
Veritech
Hello everyone. Im new to this forum. I started using this great app. Can someone upload last channel list pls? Also what basic plugins I need for this great app to work? Thank you.
In most cases you don't need plug-ins at all.
And without more informations nobody can give you a fitting channel list.
What are you receive with your hardware (DVB-T, DVB-C or DVB-S). And which provider (city, cable company or sat position).
You can generate/update the channel list by you own.
TV/Radio > Scan channels
select the Reception Type
and a Transponder list with fits to you provider.
and click scan range
  • Like 1
Ok. Thank you. But what are good plugins? I just cant see any info about channel like resolution and format.
Thank you for your help. And which version are you using. I have some version that keeps crashing. Can you give me download link for stable version?
YES on windows 10 x64 version 5.5.2 CRASH,5.3.2 is most stabile :(
I'm using the current version:
https://www.DVBViewer.tv/members/
(that is the only place where you get the DVBViewer Pro(GE) after you bought it)
If you are using the current version. Without any Plugins and you encounter chrashes. Post a support.zip
PS: on Windows 10 you should check all drivers (are they up-to-date, ready for Win 10) speciously the graphic card an TV card driver.
Thank you for responding so quickly. I am still using Windows 7 64. I will try 5.3.2 then. I have 5.5.2. and its crashing.
with pleasure,what remote you have,is ok?
I dont have remote. Im using old pinnacle dvb-s card. Soon I will have Skystar S2. Does someone have experience with this card? Is it good?
Hey guys. I need more help please. Yesterday I had bought 1 lnb and also have other 2. All are different. I also have lnb multiholder for 3 lnb-s. Now is it possible that I connect hotbird, eutelsat and astra on 2 sat cards ( one is pinnacle PCTV 7010iX Dual and other will be Skystar S2 ) on two different PC-s? ( like 2 receivers ) Seller had offered me diseqc 4 in 1 out. I can use only one pc with ss s2 then. Is there diseqc 4 in and 2 out? Also I need help how to setup diseqc in DVBViewer for 13,16,19? I know this is many questions but I really need some help. Thank you.
Hi Veritech,
please find top useful info about DiSEqC in the DiSEqC Setting section of Transedit Manual:
Transedit use the same DVBViewer/RS concept/guide line, so better you understand directly
what you want / can do with all that hw before you try to blindly set/use it...
if somethings isn't enough clear, please post your question with all possible detail...
:bye:
Thank you for your answer. I will try it. Can anyone respond me to other questions maybe? Also what is difference between Skystar S2 and HD2? Which one is better? I read that HD2 is no longer selling or something like that.
Can someone export eutelsat 16 channel list and upload?
The best channel list you can have is the one you build yourself ;) and I suggest you to use TransEdit for that (you can download it in "Member section"); depends on the Scanner/Timeouts settings, but it take only between 3-8min to scan a sat position....
About your question "Is there diseqc 4 in and 2 out?": since every LNB have can activate only one by one their 4 "tuning section" (2 frequency bands, Low and High, and 2 polarizations, Horizontal and Vertical, so they are LV, LH, HV and HH), you can use only one receiver per LNB out, otherwise if a second receiver request a different freq/pol. it would block the first...
There are some solutions (your seller would have told you...):
+ single LNB with 2 out ie "twin out LNB", they can tune 1 sat position for 2 indipendent receivers (there are also for 4 and 8 out)
+ double twin LNB (2 sat pos x 2 indip. receivers)
+ LNB Quattro + Multiswitch:
- LNB Quattro, 1 sat pos. and 4 cable out, one for each LNB tuning section (...so you have to carry 4 cable for every LNB)
- Multiswitch can have 1 or more LNB Quattro for input, and 2 to 32 or more indipendent out (normally they're used to serve an entire building)
+ (maybe) SCR/unicable LNB, in witch unfortunately I haven't any experience...
:bye:
  • Like 1
:bye:
Thank you. Now I have clear picture :) Now I am setting 3 lnb-s for 13, 16, 19.2 . How can I find sattelite if I dont have channel list? Is there some sat finder application or something. I have list for 13 and 19.2.
