User data error 736
oldfart
New install Windows 10 Pro 64 bit
V5.5.2
used KeyTool
the data match the checksum
User data error 736
use KeyTool to correct
WHAT??
Have you downloaded the setup.exe from the members section with the same name and password now used in the Keytool?
Has the .dvbvkey file in C:\Program Files (x86)\Common Files\DVBViewer Shared\ a size of 1024 Bytes?
If yes post a support.zip
