Siddan Posted December 15, 2004 Posted December 15, 2004 (edited) hi I could need a small Guidance with this since i can´t really see anywhere and there is just too much of everything... :/ I have a dish with 4 headers or DiSEqC pointed to each satellite. I have tried a bit on both Setup4PC and DVBprog. on Setup4PC I can´t get any signal of the other DiSEqC options.. only Pos A - Opt A as it seems . Overall I just get a signal for Astra 1b as it seems. So do I need to setup the 4 satellites on both?.. and which name should be selected when rightclicking the status symbol,,, there are so bloody many hehe All I know is that is that I shuld have the DiSEqC settings in DVBprog to "1.0 or 2.0" and then add the following LNB. And that is where I am kinda stuck. I am not sure which header is pointed to which satellite but that could be tested so it won´t be difficult to see. I have tried looking at lyngsat.com but that shows where the dish should point at and so and I am just unsure about all the settings in DVBprog, like what to have in LOF1 and 2 and also Switch. My following pointed satellites are: Sirius 5 E Thor 1 W Astra 19.2 E Hotbird 13 E I would like to recieve all channels on those followings.... I live in sweden and is using the Sky Star 2 pci card thanks Edited December 15, 2004 by Siddan Quote
Siddan Posted December 17, 2004 Author Posted December 17, 2004 ok now this is funny..... Now I managed to get a few channels from Thor 1 W but ONLY in DVB Dream. I started to recieve channels from the scan option selecting Thor 2/3 and I had to rightclick Setup4PC and chose T-Systems Hotbird 13 E during the scan for it to pick up the channels, why i do not know but i did it randomly. This I cant do in DVBprog. But but nut.. seems like I can´t watch any channels in DVB Dream.. it is all black. Quote
Guest Oliver Posted December 17, 2004 Posted December 17, 2004 Maybe you should post these questions in the appropriate places, for example at http://www.progdvb.com. By the way: The Skystar doesn't support DiSEqC >1.1. There is a modified driver, though, but this one will damage your card after some time. Bye Quote
Siddan Posted December 17, 2004 Author Posted December 17, 2004 OMG this is unbelievable!! All my late hours of exploring for.... nothing grrrrrr well this sucks big time then Quote
