vxl Posted February 26, 2016 Posted February 26, 2016 I have TBS6902 and TBS5980 DVB-S/S2 tuners. My satellite configuration has DiSEqC 2.0 switch.Does anybody know if DVBViewer will work with these tuners and can handle DiSEqC 2.0 switch (2 ports)? Quote
Tjod Posted February 26, 2016 Posted February 26, 2016 The DVBViewer doesn't support DiSEqC 2.0 only DiSEqC 1.0, DiSEqC 1.1, DiSEqC 1.2. (which DiSEqC level works depends on the ) You should be able to test with the DEMO if it works with you cards. Quote
vxl Posted February 26, 2016 Author Posted February 26, 2016 As I understand, DiSEqC 2.0 ir same as DiSEqC 1.0, only 2.0 support bi-directional communications. OK, I will give a try. Thank you! Purchase of full version is possible only at working days? Quote
