How to add frequencies for DVBViewer Pro v5.6.0
serkanguzel
Hi masters,
Thank you very much for new version. ( Pro v5.6.0 )
How to add new frequencies from in the channel scan window ?
Regards.
..you have to edit the ini. Transedit is still the best choice.
Thank you for response.
Is it not possible within DVBViewer ?
Derrick,
I'm using HTPC. To add a frequency, it is difficult TransEdit. For me.
Why do you complicate works?
add frequency is a basic feature.
Please add it.
you're right :)
