aitanik92 Posted March 21, 2016 Posted March 21, 2016 Good afternoon all, is it possible to edit streaming presets during the live transcoding through browser or app? (i mean "WebM 400k" etc.) i'm getting around 700kbit/s when it comes to upload speed, but i see that i can select only 400kbit (smooth but poorest quality) or 800kbit (accettable quality but with a bit of lag due to my poor upload speed). Thanks in advance.
Tjod Posted March 21, 2016 Posted March 21, 2016 You can edit the presets. But only on the RS PC and only if the RS is stooped. The FFmpeg parameters are stored in the C:\Program Files\DVBViewer\config\ffmpegprefs.ini
