RS prefered device?
Hi.
I have just added a new DVB-C tuner to my system. I already have two other DVB-C tuners, and I would like to have the RS using those two if one of them is available, and only use the new tuner if none of the other two is free.
Earlier there was an option in RS to say that a device should be prefered.
Is there any way that I can decide which tuners the RS should use first?
I want to use the new tuner only as a last resort.
I have attached the support.zip file in case it is needed. The new tuner is the CT2-4400 USB stick.
Thanks in advance.
rco133
Now the position in the list of devices sets the priority. Move preferred devices to the top of the list.
Thanks.
Where or how do I change the order on the list?
rco133
In the usual Windows way :) Drag & drop or shift + arrow up / down key.
Thank you.
I actually tried drag&drop, but couldn't get it to work at first.
However after trying again, and dropping it on top of the last device on the list, instead of into the empty space below, it worked as it should. The shift + arrow keys also work.
Now the new tuner is at the bottom of the list as I would like it to be.
rco133
