james74 Posted March 30, 2016 Posted March 30, 2016 When I enable thumbnail creation (Service Options-Movies), the log fills up with a task that repeats every minute (61 seconds), If this is the thumbnail generator task, what would cause it to do this? 30.03.16 00:50:51.198 CreateProcessW 6820 30.03.16 00:50:51.686 Createthumb WM_DATACOPY 30.03.16 00:50:51.687 Createthumb success 30.03.16 00:50:51.701 Createthumb WM_DATACOPY 30.03.16 00:50:51.702 Createthumb success 30.03.16 00:50:51.718 Createthumb WM_DATACOPY 30.03.16 00:50:51.719 Createthumb success 30.03.16 00:50:51.735 Createthumb WM_DATACOPY 30.03.16 00:50:51.736 Createthumb success 30.03.16 00:50:51.748 Createthumb WM_DATACOPY 30.03.16 00:50:51.748 Createthumb success 30.03.16 00:51:52.216 CreateProcessW 4932 30.03.16 00:51:52.646 Createthumb WM_DATACOPY 30.03.16 00:51:52.647 Createthumb success 30.03.16 00:51:52.656 Createthumb WM_DATACOPY 30.03.16 00:51:52.656 Createthumb success 30.03.16 00:51:52.664 Createthumb WM_DATACOPY 30.03.16 00:51:52.665 Createthumb success 30.03.16 00:51:52.673 Createthumb WM_DATACOPY 30.03.16 00:51:52.674 Createthumb success 30.03.16 00:51:52.682 Createthumb WM_DATACOPY 30.03.16 00:51:52.683 Createthumb success
Tjod Posted March 30, 2016 Posted March 30, 2016 I would assume RS options > Options Service - Media libraries > Keep library automatically updated http://en.DVBViewer.tv/wiki/Options_Service_-_Media_libraries
james74 Posted March 30, 2016 Author Posted March 30, 2016 Yes, that is enabled, but the refresh interval is 30 minutes, not 1 minute. Also, nothing is being added to the libraries in that time. I cleaned and refreshed the video library. The task seems to have stopped for now. Maybe it kept looking for missing files, and the task never achieved completion. Is there a way to run vthumbs.exe manually, or would the command line need to include every library folder?
james74 Posted March 30, 2016 Author Posted March 30, 2016 Well, as soon as I start Kodi (with DVBViewer add-on), the issue re-appears. I have to disable thumbnail creation to make it stop. Disabling automatic library updates has no effect. So the problems seems related to the Kodi use of RS API. I will raise it in the appropriate forum.
