Problem scaning
androlegend
how to scan a specific frequency?
on the home screen appears to me DVB -S ,do not be DVB - S2 ???
I do not see the option to scan a specific frequency.
My card is DVB
TBS5925 DVB-S2 TV Tuner USB
You can only scan a frequency present in the selected transponder list.
You can select it by the transponder number.
meaning they can not scan 11070 V 5000 ???
or 11088 V 9874 etc etc etc ???
If the transponder is no in the transponder list no.
The best way to add a transponder is TransEdit.
and how to scan a specific frequency?
send me a picture
Select the transponder number by start and then click Scan Frequency. It will only scan the start frequency.
In you screen-shot it would be 10729 V (1)
I do not understand anything.
give me a link to take off the previous version.
what have made new is disgusting.
I pray for a quick update.
Please send me link for 5,1,1 version .
I buy program in january 2016 year.
In the previous version it was not possible either.
The only difference was that you changed the frequency an not the number of the transponder in the transponder list.
But the DVBViewer did not scant the selected frequency. But the transponder with the from the transponder list with the nearest frequency.
So there is no functionality lost. The GUI only represent it better what is happening in the background.
And there is only one place where you can get DVBViewer versions https://www.DVBViewer.tv/members/ you cant get versions which aren't available there by the old versions (and versions from other users will nt work with you license an will result in a ban of the user posting the version).
The only other solution is that you have the old version in the DVBViewer Program Folder > setup (if you haven't uninstalled a version there are all version you had installed on the PC).
I want to go back to the old, because this is very complicated.
I paid program and can not use it properly.
In current program,how change Symbole Rate, My SR is 5000,how change?
Create video tutorial,not only for me but also for the whole nation.
If I have more free time the I spend here in the Forum. I will update Wiki article. So don't expect a video tutorial from me in the next years.
  • 3 weeks later...
to be back program as previous versions...
a new version of the much complicated.
or create video TUTORIAL the new version
