new Channel scan not humane&not work(5.6.2.0)
anime5167
English by Google Translation & myself edit.
sorry for my poor englist.
the new version so hard to use (is for Professional skill??)
before just pass "scan range" botton and wait (If scan nothing, just pass again
now i don't know how to scan range
because i don't know the channel Mhz or bandwidth (default channel Mhz file no way to scan a active channel )
There are many different transmitting stations in Hong Kong and channel Mhz not the same
Now only way is use the old version
eg. TransEdit hard to use for newbies (i try few hour, still get nothing)
Lifetime Update feel is fake...............(i can't use new version to scan any channel)
It's possible older scan tool for new DVB version?
Thank you.
(image 5.4.1.0 beta)
Edited by anime5167
  • Like 1
what satellite? are you trying to scan?
your hardware?
Developers: in new versions of the program is missing files .ini. Maybe not everyone understands this.
No, that will not happen.
You need a transponder (frequency) list, which covers all transponder used in your region.
I have generate a from information I was able to find without speaking Chinese.
Put it in the (configuration folder) Transponders folder and select DTMB for the channel scan.
If there are still frequency missing, someone from the region how speaks Chinese need to provide the frequency here.
  • Like 1
I have generate a attachicon.gifDTMB.ini from information I was able to find without speaking Chinese.
no 578000/8Mhz (this have 4 channel on this frequency , Pearl/J2/iNews/J5)
no 674000/8Mhz (this have 3 channel on this frequency , RTHK TV 31/RTHK TV 32/CCTV-9 Documentary)
this two channel scan by older DVB version(5.4.1.0 beta)
this frequency is only for my Transmitting station, not FULL HongKong
map for HongKong transmitting station, all transmitting station frequency not the same
some, Digital broadcast receiver managed by the buildings, not the home user.(Resident don't need to build or setting -> Receiving antenna)
so Resident don't know what frequency need for scan channel
(by this, i don't know my house need what frequency for scan, only way is use the older DVB)
UPDATA: some buildings (For example, Myself) will be Re-frequency to broadcast to Resident
It may be the reason: Blocking some frequency( this i know)
Note. one building around 700 householder
like television, need scan form frequency start to frequency end
really really need a fool scanning tool
if no one updata the list, so the software never for newbie???
and this month have some new TV broadcast (now i can't scan the Channel on PC, but television can scan)
again, sorry for my poor english
Edited by anime5167
can't edit more.....
so
UPDATA: maybe all "Public housing" will Re-frequency to Resident
A transponder list should be covering all frequency which are used in HongKong or China.
The frequency list I had discovered was from 2014.
Here the next try DTMB.ini (hoping this one is couplet)
And therefore you need to know what are possible frequency. And that is saved in the transponder list.
Scanning 578 Mhz and 579 Mhz doesn't make scene. Because you will get the same channels but in the second case with more errors.
And ale DVBViewer developers and beta tester are based in Germany or neighboring contrary. So problems with lists for other regions of the world can only fixed if user from this region report the problems and help with informations to fix them.
so why the user need to know the possible frequency........
This I do not understand
and again.
if Re-frequency......how to know the frequency....buy a Professional tools to check ???
television won't show the using frequency
btw using this 2014 file, now can scan all 9 channel .
but i don't know will work for other buildings
not every user need to know it. But at least one DVBViewer user from Hong Kong need to collect the necessary information and provide them here.
And you are the only user from Hong Kong reporting such problems here since some years.
The list in the previews post was from 2014 now I have added more frequency.
The list will be included in future DVBViewer versions.
  • 1 month later...
plz put back old Channel scan
because very suck :( and not working good
not possible write manual freq
and not find many dvb-s freq ...
why need change old one because working good?
now revert old 5.5**** app :(
  • 7 months later...
fuck you :( not change back old scan option
why change ???
idiots how to typing manual frec ??
Edited by sonique
  • 2 months later...
A feature requests has nothing to do with support.
And the old channel scan will never come back. And insult are never the way to motivate someone to change something.
