freenow Posted April 9, 2016 Posted April 9, 2016 i have put this feed Eutelsat 7A (7.0°E) Fréquence: 10976 - Pol: V - SR: 4434 - FEC: NC Catégorie: Sport - Tennis Transmis en: MPEG-2 4:2:2 Infos: Tabletennis: woman from portugal is playing only audio and video remaign black screen. please give your help here Quote
Griga Posted April 9, 2016 Posted April 9, 2016 ffdshow as MPEG2 video decoder is able to handle almost all 4:2:2 video. After installation (32 bit version for DVBViewer!) launch the ffdshow Video Decoder Configuration from the Windows start menu, go to the Codecs page and select libavcodec for MPEG2. Finally launch DVBViewer and select ffdshow as MPEG2 Video Decoder on Options -> DirectX. Quote
freenow Posted April 9, 2016 Author Posted April 9, 2016 in this step Finally launch DVBViewer and select ffdshow as MPEG2 Video Decoder on Options -> DirectX. i dont have this choice.have only this: system default lav video decoder microsoft please help here Quote
Griga Posted April 9, 2016 Posted April 9, 2016 Make sure the 32 Bit ffdshow version ist installed. DVBViewer can't use the 64 bit version. Quote
Griga Posted April 9, 2016 Posted April 9, 2016 try LAV without DXVA I've tried. It still can't play all my 4:2:2 samples. Only some of them (two out of four). ffdshow plays them all. Quote
Derrick Posted April 9, 2016 Posted April 9, 2016 ..at least with H.264 you have to deactivate hardware acc. Quote
freenow Posted April 9, 2016 Author Posted April 9, 2016 the problem is now is playing video and after 7-8 sec is freeze and play again. only the video have this probem the audio is play fine for this feed Eutelsat 7A (7.0°E) Fréquence: 11102 - Pol: H - SR: 14400 - FEC: NC Catégorie: Sport - Football Transmis en: MPEG-4 4:2:2 Infos: VfB Stuttgart - Bayern München FTA Quote
freenow Posted April 9, 2016 Author Posted April 9, 2016 can help here please the video is freeze after play a couple se and start again. this do it again and again Quote
Derrick Posted April 9, 2016 Posted April 9, 2016 if you can watch at least for short moment, directshow should be ok. I guess your problems come the encryption of the feed. -> no discussion here. Quote
Tjod Posted April 9, 2016 Posted April 9, 2016 Check Settings >Filter > DVB Source if the Discontinuities count grows. Quote
freenow Posted April 9, 2016 Author Posted April 9, 2016 if you can watch at least for short moment, directshow should be ok. I guess your problems come the encryption of the feed. -> no discussion here. the feed is fta mate Quote
freenow Posted April 9, 2016 Author Posted April 9, 2016 Check Settings >Filter > DVB Source if the Discontinuities count grows. where can i find this?? Quote
freenow Posted April 11, 2016 Author Posted April 11, 2016 in settings>option>directx>video renderer which i must choice??? system default or some of others choice??? Quote
Derrick Posted April 11, 2016 Posted April 11, 2016 for 4:2:2 the video decoder is the important part read the wiki and post a support.zip Quote
Griga Posted April 11, 2016 Posted April 11, 2016 Usually Custom EVR is the best choice for DVBViewer Pro, particularly for OSD display. However, the Video Renderer has no influence on whether 4:2.2 can be played or not. It's the job of the Video Decoder. 1 Quote
