GinoFamussa Posted April 10, 2016 Posted April 10, 2016 (edited) Hi members, I have installed v.5.6.1 and afterthat 5.6.2 With both I have problems scanning a single transponder in the list, a range of trps in the list and single trp not in the list (a random active feed). Each time I try to scan, DVBViewer crashes and locks TBS card. I have to restart the PC. So I went back to older releases, 5.5.1 & 5.5.2, and those too have problems scanning (That doesn't happen usually at that time) I think there's some conflict with some window's update then ... I have attached support.zip Thanks in advance Gino PS: transedit works fine, I can modify trps lists, scan and find the channel... CProgramDataCMUVDVBViewersupport.zip.zip Edited April 10, 2016 by GinoFamussa Quote
Tjod Posted April 10, 2016 Posted April 10, 2016 Start the DVBViewer via "DVBViewer Pro (Debug Mode)" (start menu) and try a channel scan. Stop the DVBViewer and remove the TbsCIapi.dll start the DVBViewer via "DVBViewer Pro (Debug Mode)" and try a second channel scan. And post a new support.zip hopefully the .log gives more informations what is happening on you system. Quote
GinoFamussa Posted April 10, 2016 Author Posted April 10, 2016 (edited) Hi Admin, thank You for the quick reply I followed the instructions. Here it is. Best regards PS: since I deleted TbsCIapi.dll, scan works fine, without issues CProgramDataCMUVDVBViewersupport.zip.zip Edited April 10, 2016 by GinoFamussa Quote
