"Has a ci module" greyed for IPTV network device
gedav
I used to watch iptv with DVBViewer using my card with infinity usb unlimited. But since 5.5x version, when I want to add IPTV Network Device, the option "has a CI module" is greyed and I cannot check it. If I downgrade to an older version, for example 5.0, I can check this option and all works fine... I use Windows 10 64, but the problem is the same whith Windows 7 32... I tried to check all CI configuration during installation but nothing changes.
Can anybody help me?...
Thanks
  • 2 months later...
bump. I have the same issue.
Why is the "has a CI module" greyed in recording service for IPTV Network Device ?
In the next release "Has CI" will be enabled for IPTV network devices. I didn't know that it is needed in certain cases.
