aguiu Posted April 19, 2016 Posted April 19, 2016 (edited) I have been using DVBViewer for a lot of years without problems, but suddenly now it crashes always that i try to open it. I have tried to reinstall again, clean install, delete CMUV folder, nothing, when i try to open it crashes. Edited April 19, 2016 by aguiu Quote
Griga Posted April 19, 2016 Posted April 19, 2016 Try to start it with the -c commandline parameter (= start without playback). Does it still crash? Quote
Tjod Posted April 19, 2016 Posted April 19, 2016 Star the DVBViewer via start menu > all programs > DVBViewer > Support > DVBViewer Pro (Debug Mode) and post a support.zip after the crash. Quote
aguiu Posted April 19, 2016 Author Posted April 19, 2016 (edited) support.zip debug mode support.zip Edited April 19, 2016 by aguiu Quote
Tjod Posted April 21, 2016 Posted April 21, 2016 I have no idea. You could try moving all files from the configuration folder to a different folder (when the DVBViewer is not running) and see if it works then. Keep the default value in the DVBViewer Wizard and configure the network devices via RS Wizard (in the DVBViewer > menu > help) Quote
aguiu Posted April 21, 2016 Author Posted April 21, 2016 That is the first that i did. I deleted the configuration folder, but not works. Not works reinstalling, deleting CMUV, installing clean, nothing... Quote
aguiu Posted April 22, 2016 Author Posted April 22, 2016 Sorry, i have found the problem, a program installed in my computer was closing DVBViewer by a mistake. I have solved it. thanks Quote
Tjod Posted April 22, 2016 Posted April 22, 2016 What kind of program was it? In case someone else has a similar problem. Quote
fchobee Posted July 29, 2016 Posted July 29, 2016 Hi. When i close the app i get this crash report (otherwhise the app working nicely): Problem signature: Problem Event Name: APPCRASH Application Name: DVBViewer.exe Application Version: 5.6.4.0 Application Timestamp: 2a425e19 Fault Module Name: X.dll Fault Module Version: 0.0.0.0 Fault Module Timestamp: 2a425e19 Exception Code: c0000005 Exception Offset: 00005a5e OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1038 Additional Information 1: 03e2 Additional Information 2: 03e2365c6081f58b87017b24faf0cc49 Additional Information 3: 152b Additional Information 4: 152b61faab2df9d3d3e6aaa94e5169d1Read our privacy statement online:http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt Quote
Griga Posted July 29, 2016 Posted July 29, 2016 Fault Module Name: X.dll This file is not part of the original DVBViewer installation. Try to find and remove it. 1 Quote
