Tjod Posted April 21, 2016 Posted April 21, 2016 miniepgvars.dll is not part of the DVBViewer. If you have Problems with Plugins you should report them in topic where you got the plugin from. So the the author knows of the problem. Or if you don't know why you using the plugin just delete it. Quote
zilenk Posted April 21, 2016 Author Posted April 21, 2016 It is used to display signal strength in earlier versions worked without problems. Quote
Tjod Posted April 21, 2016 Posted April 21, 2016 If there is a problem the in the COM interface or the or Plugin API. Someone needs to report which functions are used and which has what kind of problems. So mostly only the Plugin author can report this. But my first guess would the version change in the channel.dat format. http://www.DVBViewer.tv/forum/topic/57952-channelsdat-version-19-documentation/ But that would be nothing which has to be changed in the DVBViewer. If that is a problem for a addon, it need to be fixed in the addon. Quote
zilenk Posted April 21, 2016 Author Posted April 21, 2016 I know that is not a problem in DVBViewer, I wrote that the problem occurred. When you save him, I'll get back up again. Quote
