supporttool error
hauppaugeuser
Support tool reports error OLE-Fehler 8004100E, how to make report due to Upnp issue?
Thank you.
What is the last line shown in the support tool window resp. does it create a zip file at the end?
Christian
No nothing when I click on supporttool.exe it immidiately shows this error and nothing else happends.
Tryed also in safe mode its the same so I could attach you the file, but no attach button here in window.
Edited by hauppaugeuser
Thanks this version works in XP correct. How to attach it, there is no attach option and my media does not get it.
A support.zip without a exact description of the problem is useless ;)
It contains most DVBViewer settings, some system informations and some logs. Without the information what to look for it dosen't help much.
The upnp does not work, despite it works ok in wmp. And whats the purpose of music folder in dlna if does not want to transfer mp3, at least to my blue ray player Panasonic DMP-BDT300 over dlna.
The UPnP client is not a strength of the DVBViewer. Is local mp3 playback working?
No it does not recognize any device on the network. The mp3 is not working on any software to panasonic blu ray, but Nero is able to trasfer DVB-t program in real time.
