Kiwi8 Posted April 22, 2016 Posted April 22, 2016 This is not only for the software developers. I would also like to ask the rest of the users too, whether you have simiiar experiences. I notice that occasionally, I have recordings that are of the wrong clip length, which screws up the playback. Just to give an example, suppose the clip is 1 hour. But PotPlayer detects it as only 8 seconds long, while MediaPlayerClassic detects it as 22 hours long. Could this be a problem with the reception of my TV signal? Thanks in advance. Quote
Tjod Posted April 22, 2016 Posted April 22, 2016 Likely timestamp discontinuities: http://www.DVBViewer.com/griga/TSPlayer_Manual_E/Conversion.html#MPG Quote
Kiwi8 Posted May 6, 2016 Author Posted May 6, 2016 Likely timestamp discontinuities: http://www.DVBViewer.com/griga/TSPlayer_Manual_E/Conversion.html#MPG I see... So I will have to run the program to fix it? Quote
