Character set for timer recording
robena
When you set up a timed recording, DVBViewer prevents the use of many characters, replacing them with spaces.
Windows allows characters like ' to be used for file names, there is no good reason for DVBViewer to prevent using them.
Is there a way to customize which characters are allowed? DVBViewer should not enforce naming conventions other than the Windows ones.
Edited by robena
