Kiwi8 Posted May 6, 2016 Posted May 6, 2016 I apologise if this question has been asked or there is some faq that I needed to read. I need to reinstall my OS. Other than configuration folder to back up, what else do I need to back up so that when I install DVBViewer Pro and the Recording Service everything works with the same configuration? Thank you very much in advance. Quote
Tjod Posted May 6, 2016 Posted May 6, 2016 Make sure to backup the .dvbvkey and user name and password as well. Quote
Kiwi8 Posted May 6, 2016 Author Posted May 6, 2016 Make sure to backup the .dvbvkey and user name and password as well. I see. I actually already saved the key file, user name and password into another folder. Do I need to physically move the key file back to the DVBViewer Pro directory before installation, just like the configuration folder? Quote
Tjod Posted May 7, 2016 Posted May 7, 2016 The DVBViewer setup will ask for the key file and user name/password. Quote
Kiwi8 Posted May 7, 2016 Author Posted May 7, 2016 The DVBViewer setup will ask for the key file and user name/password. Ok... thank you very much. Quote
