hauppaugeuser Posted May 12, 2016 Posted May 12, 2016 Are you able to add the v-sync option for 24 fps film content, so that you buffer delay between 25 to 24 fps and set any of the options 1:1, 2:2, 3:3 or 4:4 pulldown with correspoiding v-sync refresh rates, that under special settings could be applied in driver. Also the option when dvbveiwer is run that display automaticaly switch to 50 Hz for European market. Quote
