peterhohmann27 Posted May 14, 2016 Posted May 14, 2016 I am in Australia and for some reason I no longer get audio on 7mate (in other words it used to be fine). I have not changed anything I can remember and all other Australian free-to-air channels work fine. 7mate is an SD channel with MPEG audio. I am running DBViewerPro v5.6.2 Could anyone advise me on how to troubleshoot the problem? I have no idea. I tried changing the audio to AC3 and the other options but no result. I also rescanned all the channels but no result. Thanks for any suggestions! support.zip Quote
Griga Posted May 14, 2016 Posted May 14, 2016 http://www.DVBViewer.com/griga/DVBSource%20E/DVBSource.html#PropertyPage Quote
Tjod Posted May 14, 2016 Posted May 14, 2016 What is displayed in settings > Filter > DVB Source as Audio Format Information (second line) and Audio State when you are on the channel? Quote
peterhohmann27 Posted May 14, 2016 Author Posted May 14, 2016 Thank you for the response. I have fixed it after all. I deleted the channel and rescanned and the new one worked (I thought rescanning would refresh the channel but apparently not). I think what happened was that the channel used to be HD but is now SD, though another channel did the same (the free-to-air providers in Australia have been changing which of their channels are HD and switching to the newer MPEG4 standard). Quote
