WaLLacE Posted June 2, 2016 Posted June 2, 2016 I found that once if I stop recording service, it will make TV card not detected by DVBViewer. My config Win7, Hauppauge DTMB USB TV stick, Intel ICH8
Tjod Posted June 2, 2016 Posted June 2, 2016 If you install the RS it should handle all direct access to the TV card. The DVBViewer should only connect to the RS. If you have problems in this constellation post a support.zip
WaLLacE Posted June 3, 2016 Author Posted June 3, 2016 oh, sorry, this is the first time I submit the report. Please find the attached file for my config. support.zip
Tjod Posted June 3, 2016 Posted June 3, 2016 The configuration looks correct. The RS handles the TV card and the DVBViewer receives the signal from the RS. Therefore it is normal that the DVBViewer loses its signal if you stop the RS.
