annoying noise sometimes with DVBViewer
Hello,
since the transition to HD in France I have a problem with DVB Viewer. Occasionally there is an annoying noise. With the official software of my tuner no problem.
An idea ?
This is an example of the noise : http://www.filedropper.com/samplenoise
config :
windows 7 64bits
DVBViewer pro 5.6.2
Tuner USB : AVerTV Volar HD Nano (A867R) (last drivers)
post a support.zip and show us a screenshot of your DVB Source Filter when this happens (You can access the DVB Source Filter by clicking on the footer of the Viewer window)
Very likely you will have discontinuities (bad reception) shown or some type of problem when syncing to the audio clock.
-----OK, then it seems a know problem----
Edited by blasgl
