Windows Version requirement
I cannot find information about Windows version requirement for DVBViewer Recording Service, particularly I need to know whether it will run on Windows XP Pro and whether there are plans to drop support for this Windows version.
Thanks.
It is still tested under XP, but not as extensively as under Windows 7. Generally it should work (here it does). Support for XP including bug fixes wil be continued as long as my PC with XP (Home) is working. :)
