bounguine Posted June 13, 2016 Posted June 13, 2016 Hi to everyone! I seem to have a problem with MyGica T230. When I try to scan using it in DVBViewer the system go to BSOD. In TransEdit scanning is also impossible - "Initializing the DVB device has failed". I did the scanning again in MediaPortal and it's OK there. Is there any workaround? Quote
allanlee Posted June 14, 2016 Posted June 14, 2016 I'm also using T230 but never had such problem. Post the details from BlueScreenView might help to understand more about your issue. Alternatively, you can try to update the driver to this version. Keep in mind if you have other software accessing the DVB device it's better not to have them running together with DVBViewer/TransEdit. Quote
bounguine Posted June 14, 2016 Author Posted June 14, 2016 Alternatively, you can try to update the driver to this version. I use drivers sent by MyGica support in Win7 compatibility mode (working in MediaPorta): https://mega.nz/#!S8RmmB7R!yYtqOCzdtqlpr76B2DYkQJr3Hxp1Swiy8d0TUKESHUs Here's also the download link http://mygica.com/html/Support/ Keep in mind if you have other software accessing the DVB device it's better not to have them running together with DVBViewer/TransEdit Sure, I released the device by stopping MediaPortal TVServer Post the details from BlueScreenView might help to understand more about your issue. Oh, I need some time to crash my system Quote
