Nikolaech Posted June 27, 2016 Posted June 27, 2016 Hello. In the program Kodi and Emby are not displayed logos with Russian names. Logos with English name are displayed normally. In DVBViewer and RS all is well. Read more the post #92, 93, 99 http://emby.media/community/index.php?/topic/34417-DVBViewer-live-tv-plugin/page-5 Thank you
Tjod Posted June 27, 2016 Posted June 27, 2016 Open http://127.0.0.1:8089/api/getchannelsxml.html?logo=1 save the .xml zip it and post it here. Then we will see if there is a problem with the data provided by the API.
Tjod Posted June 27, 2016 Posted June 27, 2016 OK it seals there is something wrong with the URL encoding of the names for the channel logos in the RS API.
Griga Posted June 27, 2016 Posted June 27, 2016 Not with URL encoding, but with UTF-8 encoding. It's done twice. Will be fixed in the upcoming 1.33.1 bugfix release. 1
Nikolaech Posted June 27, 2016 Author Posted June 27, 2016 Thank you. Maybe I missed something. Missing launcher RS icon DVBctrl
Tjod Posted June 27, 2016 Posted June 27, 2016 In Windows 10 there are no sub folders in the start menu any more. Therefore we have tried to reduce the number of start menu entry's generated by the DVBViewer. DVBVCtrl is mostly in auto start and running anyway, therefore there is no link generated for it in the start menu. 1
