Renaming of channels
Hi!
I noticed that any channel becomes impossible to watch right after changing its name. There was the same problem with previous v.5.6.2. Please, check this bug.
Thanks.
Edited by alexum
Confirmed. Generally wrong data is stored in case of IPTV if you click Apply on the right side of the channel editor. It would have been good to get this report before the 5.6.3 release. ;)
However, there is a work-around for renaming: Slowly double-click the name on the left side of the channel editor in order to change it in-place. That should work without trouble.
  • Like 1
