Streaming to the smart tv ¿how?
xtrapeque
Hello, i see multiple post of streaming to tvs.
My problem is, how i can?
I configured the recording service for streaming, but in the smartv? How is made?
Who direction, port, or ¿? For connect write in the smart tv
Ant manual? Please help me
Very thanks
I want streaming iptv for my house for my other house in the beach, the tv is a samsung
IPTV don't specify a protocol.
Samsung doesn't support Sat>IP as far as I know directly.
So you can try UPnP or it depends on the Apps supported by the TV.
If that are no general Android Apps you need to look which media players are available and what they support.
The best would be to get Sat>IP support on the TV.
For the RS make sure that everything works in the DVBViewer Client and the "UPnP AV Server" is enabled.
http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide
For the rest you have to look in the Manuel of your TV.
Start with 127.0.0.1 that should make no difference. The use the IP of the PC but try it local. This should make no difference (if you have not manually blacklisted the IP in the RS).
If that works bu you can't accesses the web interface or streams on other PC mostly the firewall open the PC with the RS is blocking to much.
