TIGRU.NET Posted July 8, 2016 Posted July 8, 2016 Hello, I am pressing record, nothing happens, no notifications, no hdd recording, only task appears in timer recordings. Restarting DVBViewer PRO, the task from timer recording starts, hdd recording ok, tray notification recording ok. Restarting DVBViewer PRO, i am pressing record, nothing happens, no notifications, no hdd recording, only task appears in timer recordings. Restarting DVBViewer PRO, the task from timer recording start, hdd recording ok, tray notification recording ok... Lol, what is the problem with the dvb recording service?
TIGRU.NET Posted July 9, 2016 Author Posted July 9, 2016 (edited) Please help support.zip Edited July 9, 2016 by TIGRU.NET
Tjod Posted July 9, 2016 Posted July 9, 2016 Install the current RS and DVBViewer Pro. Then the RS Wizard should start automatic and fix you hardware configuration. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer
