me_at_home Posted July 11, 2016 Posted July 11, 2016 (edited) HI, Installed 2 clean versions Pro 5.6.3.0 on both my machines. One is W7 Pro 32bit and the other is W10 Pro. (both have the same sat card hardware) Problem encountered: on the W7 Pro PC i can click forward and back on the Fav Star icon and the program will switch directly to the next or previous station - as expected and like all previous versions. In W10 Pro however, when i click on the FAV star i get the EPG window from the next (or previous) station at the bottom but have to push the [ENTER] key too to actually switch to the next or previous station. Just to be shure i re-installed the previous version (5.6.2.0) and that worked as expected: when clicking on the Favorite star icon, the next or previous station switched directly. When re-installing the latest version (5.6.3.0) the problem remains. Help wanted. Kind regards Chris *** UPDATE *** Just have seen this problem should be removed in the latest 5.6.4.0... will test.... Edited July 11, 2016 by me_at_home Quote
Baldyman Posted July 23, 2016 Posted July 23, 2016 Please advise if a fix has been released for this bug . updated to 5.6.4.0 today - problem persists .. Quote
Griga Posted July 24, 2016 Posted July 24, 2016 It is fixed in 5.6.4, as confirmed by several users, and you could easily fix it yourself in 5.6.3: http://www.DVBViewer.tv/forum/topic/58446-DVBViewer-563/?p=449112 Quote
Baldyman Posted July 24, 2016 Posted July 24, 2016 Griga - many thanks for the quick reply - much appreciated. Confirmed solution effective. Quote
