DVBViewer crashed if low signal or lost
mahmoud eltantawy
hello
thank you for do best work for this viewer better one i used
but only one problem from long time we have , it is DVBViewer crashed when signal low or lost then stopped work and must restart pc or waiting for long time while i can start again it
i hope you can find way when crashed so it is can work again normal without restart pc or wait for long time
it is cannot work again because it is after crashed i see it in task manager in processes and cant do end task for it ever
i hope i explain problem good and sorry for my bad english
thank you for help
Without a lot more informations that is not possible.
And if the TV card driver causes the problem, there maybe is no other solution then a better driver.
First start the DVBViewer via "DVBViewer Pro (Debug Mode)" in the start menu. Then reproduce the crashed 2-3 times while running in Debug Mode and poste a support.zip.
