Android Build
JakeBlake
Hi y'all,
i downloaded the TV App today and i wonder if i can watch iptv or listen to internet radio. So far it seem to be a european only solution, right?
Jake
You can import m3u or plist playlists under menu->settings->sort channels
Then press the import button (down right).
A plist look like this:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<array>
<dict>
<key>name</key>
<string>Station</string>
<key>description</key>
<string>News</string>
<key>url</key>
<string>http://videourl.com/plst.m3u8</string>
<key>icon</key>
<string>http://videoLogos/station.png</string>
<key>quality</key>
<string>720p</string>
</dict>
While looking to my code, i have to fix the logo downloader. The rest should run fine.
Thank you for the url. There are two bugs inside the current version. The first is that the imported file is not saved. The second one is that the ending has to be .plist for plist, otherwise the app tries to read the stream as m3u. I fixed this, but it needs some tests. Same with the logo loading algorithm. I have to find a smart and fast solution for this.
