BnO Posted July 25, 2016 Posted July 25, 2016 A lot of TV remote controls have a button for toggling back and forth between two channels. I haven't found that feature in the DVBViewer user interface. It should be easy to implement. Quote
Griga Posted July 25, 2016 Posted July 25, 2016 Main Menu -> TV / Radio -> Last Channel. It should be easy to find. Quote
Tjod Posted July 25, 2016 Posted July 25, 2016 Right klick in the channel list (context menu) or add a key on the remote control for it. Quote
BnO Posted July 25, 2016 Author Posted July 25, 2016 I can see now that 'Last Channel' carries out that task, but having to go through a couple of menu items to do it is not any easier than clicking on Channel Minus and then Channel Plus.Fortunately I was able to assign a simple shortcut (keyboard letter L) to do it:Settings > Options > Input > Channels > Last Channel > Learn On > L > Learn Off > OKStill, it would be even better to also have a toolbar button to click on for the same purpose. Is that easy to do? Anyway, I'm glad that I can now easily toggle between two channels.To me, that's a basic feature for a TV. Quote
