blimpie Posted August 2, 2016 Posted August 2, 2016 (edited) Dear community , I made a HTPC running Windows 10 wich holds a TBS6902 dvb-s2 dual tuner and a TBS6922SE single dvb-s2 tuner with DVBViewer Pro (no recording service yet) . I bought the program a few years ago but will be fully using it only now . . What i want to achieve is the following : - run DVBViewer Pro as a backend on my HTPC and watch live tv on the HTPC whilst recording other channel(s) and/or streaming channels to devices running Kodi @ the same time + i want the recordings to be available to my client devices to . In DVBViewer Pro my TBS6902 is shown as 6902 (0) and 6902 (1) = dual tuner = correct and the 6922SE is shown as 6922SE (3) (so as the third tuner) = correct . The TBS6902 is pointed at the 23.5 sat position and the 6922SE is pointed at 4 sat positions (19.2E + 13.0E + 23.5E + 28.2E) via a Technisat Multytenne . One coaxial cable is running from the Multytenne to the TBS6922SE tuner . => for the dual tuner (pointed to 23.5E) do i need to perform a channel scan on both tuners or will 6902 (1) use the channels automatically that were scanned with the 6902 (0) ? => next to the19.2E ,13.0E and 28.2Epositions the 6922SE also points to 23.5E...is that a problem or will that help me to be able to record channels while i'm using the dualtuner to watch tv or vice versa ? => do i need to create channel groups to avoid interference , etc...? For testing the program i scanned the 23.5E position with one tuner of the TBS6902 dual tuner card and i must say it's great . Picture quality is perfect . I can already watch television and record that same channel but no other channel :-( . Can someone put me on my way please with the setup , i would be so grateful... Thanks in advance . Kr , blimpie Edited August 2, 2016 by blimpie Quote
Derrick Posted August 2, 2016 Posted August 2, 2016 What i want to achieve is the following : - run DVBViewer Pro as a backend on my HTPC and watch live tv on the HTPC whilst recording other channel(s) and/or streaming channels to devices running Kodi @ the same time + i want the recordings to be available to my client devices to . therefore you'll need to install the RS for the dual tuner (pointed to 23.5E) do i need to perform a channel scan on both tuners only a single scan is required do i need to create channel groups to avoid interference , etc...? yes, one group for 23.5E. This group will be assigned to both tuners of your 6902 and another group for the rest. Quote
blimpie Posted August 2, 2016 Author Posted August 2, 2016 Hello Derrick , thx for the reply , that will help a lot ! Only stil a bit puzzeld about the channet groups ; you said : -> yes, one group for 23.5E. This group will be assigned to both tuners of your 6902 and another group for the rest. => so should i scan for channels via my TBS6902 dual tuner and assing them to channel group A for instance....and scan every sat position (19.2E + 13.0E + 23.5E + 28.2E) with my TBS6922SE and assing all to channel group B for instance (including the 23.5 position scanned with this single tuner TBS6922SE ,because this tuner is pointed also @ 23.5E) Thank you so much . Kr , blimpie Quote
Derrick Posted August 2, 2016 Posted August 2, 2016 yes, almost A for 23,5E B for 19E, 13E and 28E A for both tuners of tBS6902 A + B for TBS6922SE /edit take B for 23,5E. Then you can use default lists with A for all other positions Quote
blimpie Posted August 2, 2016 Author Posted August 2, 2016 Ok , - I'll do the 23.5E scan via TBS6902 dual tuner and assign a channel group B - secondly i'll scan 19E, 13E and 28E with TBS6922SE and assign channel group A - finally i'll scan 23.5E with with TBS6922SE and assign A + B for that ...if i understood you correctly ? Thx. Quote
Derrick Posted August 2, 2016 Posted August 2, 2016 - finally i'll scan 23.5E with with TBS6922SE and assign A + B for that ...if i understood you correctly ? no, you've already scanned 23,5E in the 1st step. There's a common channel list for all devices but each device can only access the channels within the matching group(s). Quote
