need help with error 0x80040218 cant render media stream
Nolan
hi
i reinstalled DVBViewer pro on a new pc, and when trying to watch national geographic channel SD i got the error;
cant render media file, error 0x80040218, there are no combination of filters to show the stream
any idea ?
i got this on other channels too
see attached screenshot
PS located Denmark. Using windows 10 home, TERRATEC Cinergy HTC USB XS HD DVB-T/C
thanks
Jorn
EDIT: Its solved by installing K-LITE codec pack :-) Thanks
Edited by Nolan
thank you. i will do that.
  1. Why is that a better solution ?
  2. should i prior hereto uninstall the codec pack?
Jorn
codec packs install much you'll never need as a time bomb. Much later you might get troubles..
So try keeping the system clean installing only the things you really need as LAV.
ok good point. I have uninstalled the codec pack and instaleld the LAV components - it workd fine now - thank you again ;-)
