request hotbird channels
aramrahgozar
Hi
because of low signal and parasite in my city , i don't have all hotbird channels. any body can upload this channels for me?(i know still i don't have signal for whatching but i want to have channels )
there ara 2 file in this directory:
C:\ProgramData\CMUV\DVBViewer
_channels.bak
_channels.dat
Thanks
The channels.bak is only used if the channels.dat is damaged.
And the default _channels.dat is only used if no channels.dat exits.
So the channels.dat is the relevant file. But for sharing exporting the channels in the channel list editor as .ini is the best solution.
You can then import the via drag and drop on the channel list editor.
Thank all of you
now i have channels and when cut parasite , i can watch useful channels.
Merce
