Controlling the app on an Android TV.
Cian
My suggestion is for the Android app to have a version/option for use with an Android TV box. At the moment, you need to use a mouse to navigate through the menus when using the DVBViewer App. The Plex app allows the user to select between touch-screen control or an Up/Down/Left/Right/Enter Infra-red remote control option. (There must be a shorter way to describe that type on control!!)
As ever, thanks for all the fab work!
C.
Edited by Cian
