Downgrade recording service
rustynuts
Since the latest update I've been unable to recorded [removed, violating forum rule §13] encrypted channels or playback these channels in Kodi. I have been told that if I reload an early version of RS it should fix the problem.
Has anyone else had this issue and where can I locate a previous RS.
Thanks
If you don't have the RS setup in C:\Program Files (x86)\DVBViewer\setup\ on your PC from old installation the Members Section is the only place to get the RS.
If the developer don't provide old versions there there is no chance to get a older version.
