Not finding many channels on 19.2e
hse
Hello, when I scan 19.2e on my sat receiver I find well over a thousand channels, when I scan it in DVBViewer (same dish / lnb / co-ax ) I only find around 200 channels :( hundreds are missing :( I'm using a transponder file from satellites-xml.eu anybody know whats up, or can help me? thanks in advance
EDIT: Just did a scan on 28.2e also and only found 156 channels :( so again many hundreds are missing :(
Edited by hse
  • Like 1
Are the DiSEqC settings correct?
Are the channels you are finding from the Sat position you are trying to scan?
It there a conmen thing for all missing channels (polarisation horizontal/vertical, only frequency below or a both 11,7 GHz)?
The diseqc is set to angular positioner but it looks like it has stopped moving the dish
No, it looks like the channels are from 7e
