No video / no audio...but in fact everything works
martin84
Hi
Using DVBViever for + 4 years, sitting all the time on the old 4.9.60 version. on XP (worked like a charm for years). So sorry for mentioning here that version, but maybe the problem is more common, don't know.
This happened after BSOD restart, but i think bsod are quite similar with all these DVB Cards and its more a hardware thing, especially when watching some other web videos in same time. Happens... but never with such a weird effect like now.
I regret not copy the working DVBViewer folder earlier, probably that would resolve this case, but maybe some of you got similar problems in the past, or simply know more about all these filters mystery or DVBViewer itself.
So the details:
- in the options direct x nothing changed, same good config /cyberlink ffdshow/ same in hardware list
- In main window after clicking a channel name from the list there is no video / audio on screen - the channel search or green signal level in statusbar are shown and working OK, teletext is displayed correct - so for sure that's not a problem with dvb card or sat config
- When I click View/Preview I can see any fta channel in that small window without problems,
- and more if I click any fta channel and start to record it, although there is no video and audio on the screen it is in fact recorded properly and i can watch it few seconds later in wmp or DVBViewer itself
- and most funny thing - if I open any of previously recorded files, from today or from the past the same DVBViewer on the same filters (cyberlink fffdshow/) opens it. This time view/filters click and all that stats there are shown correct ?!
-but in the main window if i try to click and watch any channel only filter i see is dvb source and when i click on it (audio/video state - no date/unconnected
My Other /even older/ DVB software - P...dvb still working on the same system and codecs.
Any ideas? I really don't know what sort of filters conflict accured or what's the reason not allowing the channels to be displayed.
Perhaps the best option is direct to uninstall and update to the current version, but maybe the solution is easier than it seems to be. Some sort of restart or reload of the filters etc.
Thank you.
