userip Posted October 10, 2016 Posted October 10, 2016 Hi, I would request to make an UWP (Universal Windows Platform) compatible version of the DVBViewer. As iOS and Android version is now avaible, perhaps a Windows 10 Universal APP can be developed soon. My target is the XBOX ONE (not the Windows Phone platform) Regards! 1 Quote
hackbart Posted October 10, 2016 Posted October 10, 2016 The DVBViewer is made in Delphi and unless Embarcadero will add support for UWP it is pretty unlikely Quote
userip Posted October 21, 2016 Author Posted October 21, 2016 Hi Hackbart, Thank you for the response! I hope soon the Embarcadero IDE will support UWP. Quote
AdamBoltGC Posted January 3, 2017 Posted January 3, 2017 I also would like to see a UWP app so that I can run it from my Win 10 PC or Win 10 mobile phone. Quote
Hansrh Posted January 3, 2017 Posted January 3, 2017 If You have RS installed You can install TV Client for Windows 10 from Windows store : http://www.DVBViewer.tv/forum/topic/55326-streaming-to-windows-phone-windows-10/page-3#entry441176 Quote
userip Posted January 12, 2017 Author Posted January 12, 2017 If You have RS installed You can install TV Client for Windows 10 from Windows store : http://www.DVBViewer.tv/forum/topic/55326-streaming-to-windows-phone-windows-10/page-3#entry441176 Hi, It supports SAT>IP ? I'm only interested on UWP native SAT>IP clients... If it depends on RS (or the future MS) then it's out-of-scope. Thank you. Quote
