componenet download but not install
memo48
hallo
DVBViewer pro component downloader setup
please help me
DVBViewer pro 5.6.4
microsoft visual c++ 2005 say but setup not finish not install
windows xp pro sp3
please help me
Which hardware are you using and do you need CI or remote control support.
If not needed you can just skip the installation of the API dll. Only they need the visual c++ 2005 runtime.
first thank you for your ansver
i have SkyStar USB 2 HD CI
d-smart cam modul
This is a relabeled Twinhan device. Which doesn't need additional API dll (CI/Remote) for CAM support.
but not open d-smart cam modul channels others channels no problem ok open
i dont understand " Which doesn't need additional API dll (CI/Remote) for CAM support. " sory
please help me
Edited by memo48
Remove all selections in the hardware section. You don't need them.
Only install things you know you need.
And don't open new topics for this problem.
It is possible that the Microsoft Visual c++ 2005 runtime isn't compatible with XP any more.
And I will not spend time on a problem of person which try to install unnecessary stuff.
