Angular position mixed up
Daysi
Since I could not get DVBViewer to work but had a signal I did a blindscan in transedit.
By choosing 19.2E and a blindscan I got all channels from 28E. (Bskyb etc).
So my pc thinks the satelite is 19.2 but it realy is 28E.
I use a stab and set the angular position.
How do I get the pc to think it's 28E i.s.o. 19.2E?
I turned off angular position but that did not help.
Is there a file I can edit?
Thanks i.a.
Gerard.
Yes I did and I think this is not the problem.
What happened was that I changed from one card to another, installed DVBViewer again, installed Win 10 and updates, so lost track of where the problem started.
Now I need it to get resolved.
OK, Turned off angular position in transedit for all satelites. Saved it. Did a blind scan of the satelite I was watching. Saved it again (update). Turned on anular position on all satelites, saved it. And then I could scan the other satelites and view them in DVBViewer.
