HELP!!! I have greaaaaaaaat problem
Darijan
yesterday i got sky star 2 card
newest (2.3) with remote control
the guy who brought to me forgott cd and i had to download the drivers and program
it was about 21MB
now i instaled it (i didn't configure IR )
i start DVBViewer (i use media player 10)
and i shows this:
"cannot set tunerstatus (wrong setings),error:
0x90010115 (unknown error code)"
now i was viewing the options and other stuff
and i told him to scan for tv and radio programs on astra 19.2E
(the antena is correctly turned becouse i used analog sat )
after search i had some 20 or so programs with 2 locked radio
and of this 20 programs not all are open-able (even unlocked)
what i opened doesent have sound and the picture shows than freezes for longer time
WHAT IS THE PROBLEM??????
after that i saw something red in my taskbar
i clicked on it and setup4pc started
i browesed what i can do with this
and i found
transporder manager and there scan
i clicked on scan and he scaned for about half hour (trough scaning progress this red button somethime was green)
now it showed many transporders
i click on first - still red
i click on second - it turned green
i left it on that
WHAT IS THIS FOR AND HOW TO USE IT??
and yes,
the signal for tv programs is greater thatn 60%
and for transporder is from 75 to more
HELP ME SOMEONE
Do you read the manual?
thx for help
i fixed the problem
as i said the guy forgotten the cd
he brought it today
and i instaled it from there and
it works
but progdvb doesn't
OK, but for ProgDVB you don't get support here. Maybe in ProgDVBForum ?
