OSD Sleeptimer Plugin
Yes the \OSDSkins\default\mysleeptimer.xml in the .zip is not updated for the current default OSD-Skin (in other OSD Skins need to be supported by the Skin developer as well).
But you can get a mysleeptimer.xml for the current current default OSD-Skin ther: http://www.DVBViewer.tv/forum/topic/47490-envy-skin/page-3#entry382749
If you copy the mysleeptimer.xml from the .zip to \DVBViewer\OSDSkins\OldDefault\ and select OldDefault as the OSD Skin in the DVBViewer. It works without problems as well.
I wait update for X-skin Black glass beta 0.5 ...
Or other OSD ...
Better ask in the topic of the OSD Skin if someone can help building one if it not already exists. May skis inclined the Special paces for OSD based plug-in.
  • Like 1
