rodjd Posted October 24, 2016 Posted October 24, 2016 Why It is not option too arrange channel list,please reply best option,NOT favorite ! Quote
rodjd Posted October 24, 2016 Author Posted October 24, 2016 (edited) Thank you for reply but in editor is too hard exemple:http://s21.postimg.org/lvvlpslfr/DVB_Viewer_Channellist.png without folder and move up/down channel,understand ? Edited October 24, 2016 by rodjd Quote
Tjod Posted October 24, 2016 Posted October 24, 2016 (edited) You can put every thing in one folder. But there will be always folder. http://en.DVBViewer.tv/wiki/Channel_Editor After sorting the channel you can hide the folder in the channel list context menu > Group by > none Edited October 24, 2016 by Tjod 1 Quote
rodjd Posted October 24, 2016 Author Posted October 24, 2016 http://en.DVBViewer.tv/wiki/Channel_Editor http://www.DVBViewer.tv/forum/topic/48096-how-to-change-channels-numbers-and-order/ free editor ? Quote
rodjd Posted October 24, 2016 Author Posted October 24, 2016 (edited) You can put every thing in one folder. But there will be always folder. http://en.DVBViewer.tv/wiki/Channel_Editor After sorting the channel you can hide the folder in the channel list context menu > Group by > none Tjod why do not insert simpler in http://s21.postimg.o...Channellist.png to be able sort channel ? Why not update this http://www.DVBViewer.com/en/?page=downloads channel editor ? Edited October 24, 2016 by rodjd Quote
rodjd Posted October 24, 2016 Author Posted October 24, 2016 157 channel sort in 1 hour with this http://www.DVBViewer...?page=downloads channel editor . Quote
Tjod Posted October 24, 2016 Posted October 24, 2016 There are thee channel list editor and I prefer the integrated one. Second choice would be XchannelEdit http://www.DVBViewer.tv/forum/topic/57824-xchanneledit/ Then I would export the channel list as csv and sort it in Excel. And only if non of this three options exist I would use ancient version from DVBViewer.com Download. 1 Quote
rodjd Posted October 24, 2016 Author Posted October 24, 2016 (edited) thank you...Second choice http://www.DVBViewer...4-xchanneledit/ Edited October 24, 2016 by rodjd Quote
