Problems after formatting
madsen
Hi guys,
I recently formatted my computer, and of course i installed DVBViewer again, but i encountered a problem. I dont think that it is a DVB problem, but maybe someone has the soloution anyway :)
Here goes:
I have two monitors.
Monitor 1 (primary) and monitor 2.
When i open DVB and drag the window to monitor 1 and maximizes the window - all OK
When i open DVB and drag the window to monitor 2 and maximizes the window - BSOD with the stopcode - VIDEO_SCHEDULER_INTERNAL_ERROR (need to restart)
here comes the tricky part - if i change monitor 2 to primary monitor, i am allowed to maximize DVB on both monitors without any problems..
But off course i want monitor 1 to be primary as it is the left one of the two - but i cant seem to find any soloution to solve this :/
So, any ideas?
Thanks.
Are you using the current DVBViewer and is the graphic card driver up-to-date (the part where the BSOD mostly occurred)?
If yes you could try is changing Options > DirectX >> Reset device on monitor change helps.
Yes and yes ;)
But i have to say thanks anyway, because you lead me on the right track. In that dialog in settings i saw that the decoder was set to system default. All i had to do was change that into LAV and now it works :)
So thanks for guiding me on the right path :)
